for your GPU, is the sound a solid continuous squeal? if so, it is just a capacitor squeal and that is normal.
for your SMP clients, I'm not quite sure what is going on..
try reinstalling with requesting idle usage @ 100% and set priority in the task manager to low.
this will make you fold most efficiently, and the SMP clients will allow any other program that needs the CPU power to just use it.
Client settings: Using Idle cores @ 25% |
