I wouldn't be so sure that an 850w PSU is enough for two GTX 295's. The only certified SLI PSU's for that card are all 1200w. I'm not saying you need that much, 850w might be cutting it close.
Originally Posted by DeadSkull ![]() Its not the psu, noobs. Full load two gtx 295s only pull 300W by themselves. See this as well for gtx 295 system load. Im betting OPs problem is with leftover older drivers. Do a complete OS reinstall, install one card then install nv drivers then plug in second card. |
Originally Posted by iampoor ![]() I wouldn't call these people "noobs" And yes it could still be his PSU, He is cutting it close on the 12v rails. |
Originally Posted by orbiter ![]() I don't know where you get those figures but they're wrong, 1 x GTX295 pulls around 280W on it's own. Even with one card Nvidia recommend a 680W PSU. |
Originally Posted by DeadSkull ![]() Its not the psu. At full load two gtx 295s only pull 300W by themselves. See this as well for gtx 295 system load. |
Originally Posted by thlnk3r ![]() DeadSkull, that is interesting. I wonder why Evga advertises the card using close to 300 watts (289w to be exact) ![]() The total system power results from your first link look extremely low. At full load, total system power is only 169 watts. That just doesn't seem right. Bit-tech has some different numbers here. All though I still don't believe 54amps is enough for two cards, two hard drives and a quad core. Oneluvballer21, you wouldn't happen to have a device that allows you to monitor power draw (wattage/amperage) during idle and load would you? Good luck |
Originally Posted by orbiter ![]() DeadSkull why you lol? System power consumption Load (second chart) on the Page YOU quoted...Shows a 394w load with 1x GTX295. Also note that the test system has only 1 HDD, and a minimal overcock. Edit :- Fully loaded, My system uses around 580W max. |
