1 - 20 of 21 Posts
Hi there,
I'm going to make a build next month with a limit of 700 dollars. Ive been out of the loop for awhile so i need some help. I would like an AMD quad and i would like my build to be energy efficent but can easily play Star wars: The old republic and most new games coming out. (perhaps 5770?) make it happen people (thanks a ton) and newegg only.
oh and i love clear sides on my cases
ASUS M4A78T-E or ASUS M4A89GTD PRO/USB3
OCZ Gold 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model OCZ3G1066LV4GK
Antec Nine Hundred
XFX HD-577A-ZNFC Radeon HD 5770
COOLER MASTER Silent Pro M600
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - OEM
AMD Athlon II X4 640
Western Digital Caviar Blue WD1600AAJS
SUBTOTAL=$709.92
Filthy Casual
Sry, couldn't get newegg to allow me to save a public wishlist. I will post it as soon as I as newegg is cooperating again.
Update27-118-039
Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B
Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B - OEM
Model #:AD-7260S-0B
Item #:N82E16827118039
Return Policy:Standard Return Policy
In Stock
Note (Add27-118-039)
Save Cancel
$19.99 $19.99
Update24-236-094
Asus VE205T 20" WideScreen LCD Monitor w/Speakers - Retail
Model #:VE205T
Item #:N82E16824236094
Return Policy:Monitor Standard Return Policy
In Stock
Note (Add24-236-094)
Save Cancel
$149.99 -$25.00 Instant $124.99
Update22-136-098
Western Digital Caviar Blue WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WD3200AAJS
Item #:N82E16822136098
In Stock
Note (Add22-136-098)
Save Cancel
$44.99 $44.99
Update20-211-066
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model AD2U800B1G5-DRH
Model #:AD2U800B1G5-DRH
Item #:N82E16820211066
Return Policy:Memory Standard Return Policy
In Stock
Note (Add20-211-066)
Save Cancel
$33.99 $33.99
Update13-128-342
GIGABYTE GA-MA74GM-S2 AM3/AM2+/AM2 AMD 740G Micro ATX AMD Motherboard
Model #:GA-MA74GM-S2
Item #:N82E16813128342
In Stock
Note (Add13-128-342)
Save Cancel
$54.99 $54.99
Update17-182-044
Rosewill Stallion Series RD500-2DB 500W ATX12V Power Supply
Model #:RD500-2DB
Item #:N82E16817182044
In Stock
Note (Add17-182-044)
Save Cancel
$59.99 -$15.00 Instant $44.99
Update14-102-898
SAPPHIRE Vapor-X 100283VX-2L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
SAPPHIRE Vapor-X 100283VX-2L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support ...
Model #:100283VX-2L
Item #:N82E16814102898
Return Policy:VGA Standard Return Policy
In Stock
Mail in Rebate Card14-102-898
Note (Add14-102-898)
Save Cancel
$159.99 -$15.00 Instant $144.99
Update19-103-471
AMD Phenom II X4 940 Black Edition Deneb 3.0GHz Socket AM2+ 125W Quad-Core Processor HDZ940XCGIBOX
Model #:HDZ940XCGIBOX
Item #:N82E16819103471
Return Policy:CPU Replacement Only Return Policy
In Stock
Note (Add19-103-471)
Save Cancel
$135.99 $135.99
Update11-144-109
APEVIA X-QPACK-AL/420 Black/Silver Aluminum MicroATX Desktop Computer Case 420W Power Supply
Model #:X-QPACK-AL/420
Item #:N82E16811144109
In Stock
Note (Add11-144-109)
Save Cancel
$89.99 -$10.00 Instant $79.99
Total: $684
Antec Nine Hundred
SUBTOTAL=$709.92
Swap the CM PSU for an XFX, better models and more wattage for less
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207002
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207007
Reactions: Triangle
Buy the Core parts CPU/MB/GPU anything else u can find on the Forsale section man. Crazy deals be popping up. like the 1090t that sold for 160
PSU 89.99$ (-30$ MIR)
Video card 129.99$ (-30$ MIR)
Memory main option 44.99$ (-20$ MIR)
Memory 2nd option 64.99$
Memory 3rd option 69.99$
Memory 4th option 69.99$
Mobo + CPU main option 183.99$ (-15$ MIR)
Mobo 2nd option 94.99$ Open Box (if ur not worried about OB then u gonna save a good 55$ and get a nice mobo)
CPU 99.99$ (if u went with open box mobo)
Case 1st option 89.99$ <-personal preference
Case 2nd option 89.99$
CPU cooler 29.99$
HDD 69.99$
DVD\RW 15.99$ (dont forget to enter free shipping code)
grand total with shipping + taxes : 654.92$ , after mail in rebates : 559.92$
after you get MIRs grab another 5770 for CF
good luck !
Originally Posted by RabbitGT
[Insert RabbitGT's build suggestion here]
A few thoughts on this:
-First OCZ RAM is out of stock now sadly
-Replace the latter 3 memory choices with the Ripjaws 7-8-7 (6-8-6 capable) for $65
-If you don't mind a PSU downgrade to 520W (still reliable), replace the PSU/GPU with this PSU/GPU for $150, $130 AR
-Always get Samsung F3 1TB from Superbiiz (cheaper, faster shipping)
Always get Hyper 212+ from -buy.com (Much cheaper due to free shipping)
Some cases I also have for you:
HEC Blitz - $30 shipped (Best budget case right now)
Rosewill Destroyer - $55 shipped (Great for this price range)
NZXT Tempest EVO - $90 shipped (My personal favourite at $90 price range)
I might add on some more deals later if I can find any that are ridiculously good, but a combination of RabbitGT's and the one right below it look to be the best ones here.
The x4 940 will not work with that motherboard, it is AM2+ socket and DDR2 only.
You made a poor, blatant RAM choice there. What I hate the most is seeing people cheap out or skimp out on RAM and get the most ripoff 1333 CAS9 kit possible. Go with either of these instead:
OCZ Special Ops 1600 CAS8 - $45 shipped (6-8-6 capable)
GeIL Value 1600 CAS9 - $46 shipped
Corsair XMS3 1600 CAS9 - $50, $40 shipped
Also as I said go with the Samsung F3 1TB on Superbiiz, it is cheaper than a 500GB.
Filthy Casual
This ^
Discussion Starter · #19 ·
calm downnn
the ram i picked out is almost the same price of what you picked out, it was just a slight oversight. i picked ripjaws because ive had good luck with them in the past. but if there is better ram out there for close to the same price of course i would go for them (what you showed me)
i switched the processor up to this
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
and ram to this
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144461
I was more concerned about you pairing the AM2+ processor with the AM3 socket. Aside from the fact that it won't fit, if you remove the pins that allow it to it still won't work for several reasons.
1 - 20 of 21 Posts
