I think most people here will tell you to stay away from WC kits. You should just get a nice custom set up to cool the i7!
Originally Posted by HITandRUN ![]() I think most people here will tell you to stay away from WC kits. You should just get a nice custom set up to cool the i7! |
Originally Posted by iquark ![]() If you absolutely must get a kit, then go to Petra's and pickup either the basic or elite. They have pretty much the only decent kits around as they're basically a low end custom setup. If you really want to go liquid, then spend some time on the forums researching and build your own. Low-end liquid is not as good as high-end air, you've been warned. |
