1 - 7 of 7 Posts
Wich one will be best for AMD PHENOM II X4 955BE?
Xigmatek Scorpion Heatpipe Direct Touch or Coolermaster Aquagate Mini R120?
That coolermaster thing is way dated. If you want an all-in-one watercooloing, go h50 or h70 by corsair. That xigmatek don't look bad, but it might not fit. What kind of case do you have?
I guess I'd go w/ the xigmatek if it's only a couple bucks.
I'm not an Intel guy, buy to my knowledge, the i920 is miles away f/m the core duo. The core is a dual core while the i920 is a quad(but theoretical octa?)
1 - 7 of 7 Posts
