1 - 20 of 35 Posts
hi guys i way in to the game
But now it says cant find signal and stops working.
I am at 72. power out.
this is what i have tryed to fix it.
reinstall the game tried 6 different nvidia drivers with sli enabled and dis abled.
reinstall windows 7 64.
updated with both patches.
with vsync on and off
i even tryed deleting the level from save games and re playing it
this is where i am in the game and it will not load in to the next level
i an so mad.
pics
· Not new to Overclock.net
Did you say that you had a power outage?
Sandy Bridges aren't made for gaming are they? Am i wrong? I thought sandy bridges are just for overclocking?
Have you checked your drivers for everything? Bios too?
Oh he has a sli set up.
I'm seeing so many sli users have problems. Maybe disable that in the game or get a driver patch installed and try it?
Can be anything.
If he got that far into the game, then it's not the CPU.
Originally Posted by ____
Why?!!!?!
Maybe because he wanted to do everything he could possibly think of before coming here and making a thread.
What program are you running so you can see your fps and gpu temp in your left corner of the screen?
Originally Posted by SadSoul
Is it a pirated copy??
This.
Please be honest because we need to know everything in order to help diagnose this problem!
Originally Posted by Rabbs
I seriously DOUBT he went through all that trouble trying to figure out what's going on if it was a pirated version.
I dunno... I think I would have.
No you wouldn't of, you would of re-downloaded another up loaders copy to see if it worked. But i own the retail version and this hasn't happened to me at all.
No, I would have. I would have done everything I could in order to avoid the risk of getting a virus by downloading another copy.
Don't tell me what I would've done. You don't know me as well as I do.
So anyway, what are some other possible causes for this problem?
Discussion Starter · #15 ·
no its good.
What program are you running so you can see your fps and gpu temp in your left corner of the screen? msi afterburner
i even put the hole pc to stock cpu and gpu.s
you pay 70 buck for a game that you can,t even finish
and twocables my pc i fine after the power went out i got a good surge protector
i google and see other guy have this problem to.
__________________
no its good.
__________________
Which surge suppressor do you have? What's the brand and model? I don't mean to look like I'm doubting you, but I am just curious.
However, if you're not alone in this problem, then I wouldn't know what to do.
i9-12900K | Z690-E | RTX 4080 FE
LMAO, that peter parker picture got me cracking up bad. DERP! It's like y'all have pictures for all types of situations.
HAHA Glad you enjoy it ;D
As for OP, It would really help if he posted in coherent sentences.
For example I don't understand a THING from "I am at 72. power out."
What about "But now it says cant find signal and stops working."
Wh...wai... huh? Lost signal during campaign?
The only thing that comes to my head is that OP is running some in-game monitor that might be screwing with the game.
"72" means he is at the 72nd checkpoint.
"Power out" means he had a power outage.
The "signal" comment means that all of the sudden his monitor turns off.
Originally Posted by ZealotKi11er
Maybe try a pirated .exe and see if you can pass the level. Pirates > Crytek (EA)
Hmm. This!
Yeah, I know that it's a shock, but it can't hurt - just as long as you are very careful about what you download.
1 - 20 of 35 Posts
