Hello all
My friend needs a new computer. He plays quite a number of games ranging from Empire Total War, Team Fortress 2, etc. and would get newer, more demanding PC games
I was originally going to do Intel/ with an e8400 processor but then I looked into the AMD/ Phenom II X2 550 BE, which I heard performances just as good as an e8400, and much cheaper too!
I don't want it to be a super-expensive build, but i dont want to cheap out in some areas
So here is what I got so far
CPU AMD Phenom II X2 550 :
http://www.newegg.com/Product/Produc...82E16819103680
Motherboard: GIGABYTE GA-MA770T-UD3P AM3
http://www.newegg.com/Product/Produc...82E16813128392
PSU: Antec earthwatts EA500 500W
http://www.newegg.com/Product/Produc...82E16817371007
GPU XFX GS250XZDFC GeForce GTS 250 1GB
http://www.newegg.com/Product/Produc...82E16814150356
OR
I was thinking of the XFX HD-489A-ZDFC Radeon HD 4890 1GB, which is about $50 more and pretty good. Will it run with that Power Supply? It says 500 watts in the newegg specs
http://www.newegg.com/Product/Produc...82E16814150359
Case: COOLER MASTER Centurion 5
http://www.newegg.com/Product/Produc...82E16811119068
HDD: Western Digital Caviar SE WD3200AAJS 320GB
http://www.newegg.com/Product/Produc...82E16822136098
DVD burner: LITE-ON
http://www.newegg.com/Product/Produc...82E16827106291
Total is about $540
What do you guys think? I think the PSU should be good? I did one of those PSU calculators and i used all this specification and it said it needed about 300 watt, and that was with the ATI HD4890.
Thanks in advance
OR
DVD burner: LITE-ON
Total is about $540
Thanks in advance
