First off, I don't even know what version I should be using. Everywhere I look has a different version. The one linked from the Minecraft wiki uses a BAT file to launch, the one from Notch's site is a jar exe and has a GUI.
Neither work. I have the port fowarded correctly. When I try to connect to the BAT based server, it connects and then says "kicking xxx.xx.etc (my local IP) You need to log in!"
The jar executable based on, I can't get to work at all because everywhere I look people are suggesting different flags to run it with. Regardless, it keeps saying "failed to bind to port" on top of the RAM error.
Can someone first point me to the correct server files and then walk me through this?
