1 - 3 of 3 Posts
Hey ive got pre assembled pc... with the P5NSLI installed, and 1 gig of DDR2 XMS2 @ 800MHz... Now from the spec. of the MOBO i read that it only supports 667MHz... so what does this mean... what happends to the rest 133MHz? And what should i do? Thnx...
The ram just downclocks itself (I believe) to the speed of the motherboard. This also gives you some headroom when you start Overclocking. It shouldn't cause you any problems
<tr>
<div>
Originally Posted by <strong>charliemack</strong>
</div>
<div style="font-style:italic">The ram just downclocks itself (I believe) to the speed of the motherboard. This also gives you some headroom when you start Overclocking. It shouldn't cause you any problems</div>
</td>
</tr>
</table>
</div>Any performance loss? So even if i overclocked my ram to 989 its still working at 667? If yes, is there any way i can raise the "actual" clock to atleast its stock speed of 800? Thnx...
1 - 3 of 3 Posts
