Hi.
I had some issues with my PC resulting in a CMOS reset and I can't remember how to set up my RAM timings as they were.
MB: ASUS P6X58D-E
CPU: INTEL i7 950 3,06 GHz
RAM : CORSAIR 6GB DDR3 INTEL I7 DOMINATOR GT 2000MHZ CL8 (CMT6GX3M3A2000C8)
Initially the RAM speed is 1066 MHz but as my RAM is able to go faster I thought I could change some values in BIOS to make them go faster. Ufortunately my PC doesn't seem very stable when I try and fiddle with the BIOS settings. So I need help.
From what I've learned the supported speed is 1066 MHz hence the default value I guess so when I change the values it's considered overclocking (one of my ASUS programs tells me that).
I tried entering the BIOS sections "DRAM Timing Control" and enter:
DRAM CAS# Latency: 8
DRAM RAS# to CAS# Delay: 9
DRAM RAS# PRE Time: 8
DRAM RAS# ACT Time: 24
Everything else is on AUTO - but nothing changed - perhaps because the Ai Overclock Tuner is on AUTO aswell.
Both my board and my RAM supports X.M.P. so I tried the X.M.P. profile: X.M.P. Profile Info: 2000MHz-8-9-8-24-2N-1.65V-1.25V
My PC fails the memtest after about 2 loops (1½ hours) - one time leading to a corrupt BIOS. And Prime95 crashes almost instantly.
I then tried lowering the BCLK value so my CPU reached a more accurate frequency and memtest was stable after this but Prime95 still crashes - just not at once.
I then heard that setting the Ai Overclock Tuner to MANUAL is better than the X.M.P. profile even if the values are the same. I tried this but the Prime95 stille crashes .. well it frooze my Windows.
I tried using this article: http://vip.asus.com/forum/view.aspx?id=20081220191040237&board_id=1&model=P6T+Deluxe&page=1&SLanguage=en-us but I'm having a hard to understanding what does what and I'm affraid to fry the CPU or similar.
I'm hoping someone can help me - perhaps if you have a similar system (se hardware in the top).
These are my BIOS settings when on X.M.P. profile:
BIOS INFO:
CPU Ratio Setting: 22.0
Intel(R) SpeedStep(TM) Tech: Enabled
Xtreme Phase Full Power Mode: Auto
BCLK Frequency: 143
PCIE Frequency: 100
DRAM Frequency: DDR3-2006MHz
UCLK Frequency: Auto
QPI Link Data RAte: Auto
CPU Voltage Control: Manual
CPU Voltage: Auto
CPU PLL Voltage: Auto
QPI/DRAM Core Voltage: 1.40000 (PINK)
IOH Voltage: Auto
IOH PCIE Voltage: Auto
ICH Voltage: Auto
ICH PCIE Voltage: Auto
DRAM Bus Voltage: 1.65 (RED)
DRAMA DATA REF Voltage on CHA: Auto
DRAMA CTRL REF Voltage on CHA: Auto
DRAMA DATA REF Voltage on CHB: Auto
DRAMA CTRL REF Voltage on CHB: Auto
DRAMA DATA REF Voltage on CHC: Auto
DRAMA CTRL REF Voltage on CHC: Auto
Load-Line Calibration: Auto
CPU Differential Amplitude: Auto
CPU Clock Skew: Auto
CPU Spread Spectrum: Auto
IOH Clock Skew: Auto
PCIE Spread Spectrum: Auto
DRAM Timing Control:
1st Information: 8-9-8-24-7-98-14-8-28-0 (GREY)
DRAM CAS# Latency: Auto
DRAM RAS# to CAS# Delay: Auto
DRAM RAS# PRE Time: Auto
DRAM RAS# ACT Time: Auto
DRAM RAS# to RAS# Delay: Auto
DRAM REF Cycle Time: Auto
DRAM WRITE Recovery Time: Auto
DRAM READ to PRE Time: Auto
DRAM FOUR ACT WIN Time: Auto
DRAM Back-To-Back CAS# Delay: Auto
2nd Information: 2N-61-62-62 (GREY)
DRAM Timing Mode: 2N
DRAM Round Trip Latency on CHA: Auto
DRAM Round Trip Latency on CHB: Auto
DRAM Round Trip Latency on CHC: Auto
3rd Information: 7-7-19-9-9-9-7-6-4-7-7-4 (GREY)
DRAM WRITE To READ Delay(DD): Auto
DRAM WRITE To READ Delay(DR): Auto
DRAM WRITE To READ Delay(SR): Auto
DRAM READ To WRITE Delay(DD): Auto
DRAM READ To WRITE Delay(DR): Auto
DRAM READ To WRITE Delay(SR): Auto
DRAM READ To READ Delay(DD): Auto
DRAM READ To READ Delay(DR): Auto
DRAM READ To READ Delay(SR): Auto
DRAM WRITE To WRITE Delay(DD): Auto
DRAM WRITE To WRITE Delay(DR): Auto
DRAM WRITE To WRITE Delay(SR): Auto
According to CPU-Z (v. 1.60.1.x64):
General:
Type: DDR3
Channels#: Tripe
DC Mode: (GREY)
NB Frequency: 3829.8 MHz
Timings:
DRAM Frequency: 957.5 MHz
FSBRAM: 2:14
CAS# Latency (CL): 8.0 clocks
RAS# to CAS# Delay (tRCD): 9 clocks
RAS# Precharge (tRP): 8 clocks
Cycle Time (tRAS): 24 clocks
Row Refresh Cycle Time (tRFC): 98 clocks
Command Rate (CR): 2T
DRAM Idle Timer: (GREY)
Total CAS# (tRDRAM): (GREY)
Row To Column (tRCD): (GREY)
MB: ASUS P6X58D-E
BIOS INFO:
BCLK Frequency: 143
PCIE Frequency: 100
CPU Voltage: Auto
IOH Voltage: Auto
ICH Voltage: Auto
General:
Type: DDR3
Channels#: Tripe
DC Mode: (GREY)
Timings:
FSBRAM: 2:14
