Need help with setting up RAID 0
449 Views 5 Replies 3 Participants Last post by  FuNkDrSpOt
I'm getting to the point where I'm installing Vista and my computer is stopping at the 2nd screen in and is making me search for drivers.
It says the drivers are for the cd/dvd drive but I've never had an issue with that before.
Is it trying to ask me for the RAID drivers? And if so, why is it not acknowledging the dvd drive anymore?
*update* fixed it. Unfortunately for some odd reason it wouldn't let me use a burned cd, so I had to drive to kinkos to put the RAID stuff on a USB drive.
1 - 6 of 6 Posts
Unless I'm missing it, it never asks me to hit F6, that and I'm using an amd chipset
oh stupid me. I don't know about AMD raid chipsets then.
its windows that wants you to hit f6 so it can load the raid drivers with vista you can put the raid driver on a USB flash drive with XP it has to be on a floppy drive the raid driver will be on your motherboard driver disk copy it onto a USB flash drive when you first start the windows installation it will ask you to hit f6 if you want to install raid drivers. Also you have to set the array up in the bios as well thats the disks you want included in the array
Ok, well from what I was gathering, I should have been able to use a cd to load the RAID drivers.
Also, windows doesn't give me any option to hit F6 that I can see
1 - 6 of 6 Posts
