1 - 3 of 3 Posts
You might be able to use a tool like this. (if you don't need to reuse that nut)
http://www.canadiantire.ca/en/tools-hardware/power-tools-accessories/drills/drill-bits-sets-accessories/mastercraft-maximum-grab-it-4-piece-set-0543838p.html?utm_campaign=bazaarvoice&utm_medium=SearchVoice&utm_source=RatingsAndReviews&utm_content=Default#.UxuJrfldVRg
One end angles the edges of the hole. The other end digs into the hole you drill and helps you turn it. It turns the opposite way of a normal screw. Could maybe use something like that and a screw driver to hold the other side.
This will also DESTROY whatever you use it on. Not the best way to unscrew something, but it might work as a last resort.
1 - 3 of 3 Posts
