1 - 5 of 5 Posts
I need some help transfering some games from my samsung galaxy tab s to my galaxy s5 phone. Windows 10 does not recognize my galaxy tab s tablet. I have already installed the correct drivers and it does detect it.
The usb cable is fine, it charges both the tablet and the phone. The model number for the tablet is sm-t800 and the model number for the phone is sm-g900.
Thanks in advance.
What should be here ?
If you are wanting to install the games that are already on your Tab, wouldnt just adding your account used on the Tab give you access to the games on your phone's play store. Sorry if this sounds dumb but that happens on my WinPho, so I assume thats how it is on Android. What games are you looking to transfer ?
Wouldn't the progress be sync'd to your account of those games ?
As far as I know, a special designed android data backup app could transfer everything from your phone to computer, and you don't need to root your phone, just need enable usb debugging on your phone.
1 - 5 of 5 Posts
