1 - 4 of 4 Posts
I have a dual cpu intel mother board with two slot type P2 350/512/100/2.0v s1 and four sticks of 128 meg pc100 dimm ram, and what I tried to do was install two p3 933/256/133/1.7v s1 and two 1gb,sync,100MHz,CL2,ECC sticks of ram replcing the old cpu's and ram but nothing worked, the computer turned on but there was nothing on the screen. I put all my old stuff back and every thing works. The mother board is a phoenix bios version 4.0 release 6.0. I would like to know if I can upgrade to the new stuff or not??
, if I can upgrade how do I go about it??
THE HELP WOULD BE GLADLY APPRECIATED, THANKS!!!!!!!!!!!!!!!!!!!
First you need to go to user cp and fill out your system specs. If your main ssystem is not the computer you are asking about then provide me with the motherboard make and model number. You can go to the downloads section of this website and download cpu-z and the motherboard tab will on cpuz should give mr the info I need to start searching. You can also give me the info from the other tabs, that may help.
The info from CPU-Z is as follows
CPU's
Processor
name-intel p2
code name-deschutes
package-slot 1 SECC
technology-0.25
specification-intel p2 350MHz
family-6, model-5, stepping-2
ext family-0, ext model-0, revision-dB0
clocks/ cache
core speed-349.1MHz/ L1 data-16KBytes
multiplier-x3.5/ L1 code-16KBytes
FSB-99.7-99.8MHz/ level 2-512KBytes
bus-99.7-99.8MHz/
cache
L1 data cache/ L1 instructions cache
size-16kb/ size-16kb
associativity-4way/ assoc-4way
line size-32Bytes/ line size 32Bytes
L2 cache
location-on cartridge/ Ratio-1/2
siz-512kb/ frequency-174.6MHZ
assoc-4way/ bus width-64B
line size-32B / prefetch logic-no
latency-5/ ECC check-yes
Mainbord
motherbord
model-NS440BX DP 694708-221
chipset-intel i440BX/zx rev.C1
southbridge-intel 82371(PIIX4)
Bios
brand-intel corporation
version-NIGHTS0.868.0095.P14.0001211034
date-01/21/00
graphic interface
version-AGP version 0.0
transfer rate-0x max supported-2x
aperture size-4MB
side band addressing-disabled
memory
general
type-sdram
size-512MB
timings
frequency-99.8MHZ
FSB.DRAM-1:1
cas#latency-3.0 clocks
ras#to cas# delay-2 clocks
ras# precharge-2 clocks
dram idel timer-0 clocks
IF YOU NEED MORE INFO PLEASE ASK, AND THANKS FOR HELPING ME WITH THIS PROBLEM!!!!!!!!!!!!!!!!!
I have done some reading and noticed you were trying to put 2x1GB sticks in, well your board will not recognize that much. I can't find the tech sheet on Intel's website but I believe that board will only support 512 or maybe 1GB of PC100 ram or PC133 that is backwards compatible. Also that bios is the latest I could find. I will do some more research and try to give you a better answer tomorrow.
1 - 4 of 4 Posts
