Need help with WC Build
281 7
Here is the current build I have for my WC loop:
D-tek Fuzion V2
Swiftech MCP655-B Pump
Swiftech MCR320-QP Radiator
Swiftech Micro-res
3x Yate Loons High Speed
I just need help in terms of tubing, fittings (barbs), and clamps. What do you guys recommend? And specific sizes would be great! Thanks
1 - 8 of 8 Posts
I am no expert but I think these would help you or at least give you an idea.(somebody please check)
I think Tygon R-3603 for the tubing 7/16 ID and 5/8 OD: https://www.jab-tech.com/Tygon-R-360...3-pr-3957.html
or this if you want to save a little: https://www.jab-tech.com/Masterkleer...D-pr-3079.html
and get some of this to prevent kinks: https://www.jab-tech.com/PrimoChill-...e-pr-4010.html
or any color you prefer.
For the barbs I would get all 1/2 OD, so that way you will minimize the posibility of leaks since your 7/16 ID tubing is a little smaller: https://www.jab-tech.com/Dangerden-F...b-pr-4181.html
And for the clamps I would suggest to get some compression fittings if you want to spend more: https://www.jab-tech.com/Bitspower-T...6-pr-4401.html
but if not, just use some zip ties
D-tek Fuzion V2
Swiftech Micro-res
Sort of off topic, but any specific reason you're going with the D-tek v2? I've seen a few charts and reviews, and it seems the Swiftech Apogee GTZ does better on quads than the D-tek Fuzion. More than likely it's all down the users personal choice, but if you haven't checked it out, it might be worth a look!
I wouldn't get the high speed Yate Loons. The performance gain is minimal and they are a lot louder than the medium speeds. That radiator does well with low to medium speed fans.
Agree, unless you want a little more cooling power.
Discussion Starter · #8 ·
hey, i was originally going to get the swiftech, but petras doesnt have it in stock and i wanted to make my build right away. i've heard that the d-tek is pretty decent, so i went with that. thanks for your help though!
1 - 8 of 8 Posts
