1 - 8 of 8 Posts
To install a game i need to do this "Create a drive letter for your cdrom if you have not already. For each cdrom drive letter, click advanced, and set the drive type from automatic to cdrom."<br><br>
How do I do that?
not quite sure what your talking about here but you be better of fwith cedega if you want to play windows games in linux
My parents won't let me cuz it costs moneys
Discussion Starter #4
Anyone know what that means?
What it means? It means you need to give /mnt/cdrom0 (Or whatever) a letter from A to Z in wine for windows program compatability... LOL<br />
<br />
I am no help whatsoever.. I don't use wine. Just posting to say good luck I guess..
Old Timer
You need to run "winecfg" from your terminal. That will bring up a window in which you can make those changes. It should be pretty obviose once you get that far.
^^What he said. Just type "winecfg" (no quotes) from the terminal. Once the setup window pops-up select the "Drives" tab and click on "autodetect" so it lists all available drives; click on the "advanced" botton to view more options for each drive. Just make sure you have a C: drive (the virtual drive Wine uses) and that you have a letter assigned to your optical drive (make sure it has "CDROM" as its properties and not something else like "Autodetect" or "Harddrive").
Reactions: BenHagerty
Discussion Starter #8
Thanks a lot, I will try it now (I forgot about this thread lol!)
1 - 8 of 8 Posts
