1 - 6 of 6 Posts
ok i installed a new hx850watt corsair psu on sat and a ocz 40gig ssd for my os and apps but now when i go 2 play games the pc ****s itself after about 5 mins i done memtest it passed i tryed diff gpu drivers makes no diff nothing is overheating i need help thanks
are all your cables connected properly? might be that your GPU isnt getting enough juice, ensure you have the correct cables plugged in everywhere and that your GPU has the right ammount of PCI cables plugged in. or maybe check the settings you are running the game on? also could be possible due to any changed to your setup any overclocks you had may be unstable?
its all connected right, i even change the psu and it still shuts down the gpu is only 2 weeks old should i try take the ssd out and install everything on the raptor again and c if that fixes it
Discussion Starter #5
my cpu max watts is 125 right?? hwmonitor sed my cpu is at 140watts for the min and max should it be like that could that be my problem??
Super Moderator
Do u have OC the CPU? and if u can post a pic of HWmonitor.
1 - 6 of 6 Posts
