Need more Hard drives, but only 4 SATA ports?
4268 Views 15 Replies 10 Participants Last post by  Bennylava
Hi all. I am looking to get a few more hard drives for storage, but my EVGA 750i FTW motherboard only has 4 sata ports. And all 4 are already being used for my primary hard drive, a storage drive, and 2 DVD burners. So no room to add the other 3 large capacity SATA storage drives. You see people all the time on this site with 5+ hard drives. How do they do it? Is there some kind of multi-port hub or something that I can plug into one single SATA port, and it has a bunch of other SATA ports on it? Sort of like those USB hubs that have 4 or 5 usb ports, and plug into one single USB port.
1 - 16 of 16 Posts
Only problem I can think of with that is, will the speed of say... a Western Digital 640 Black, be able to saturate the PCI bus? Probly a dumb noob question, but I know the PCI bus is is pretty slow, and the hard drives are only getting faster these days.
Your average PCI slot will get about 133MB/s
SATA II can transfer at 300MB/s
But your average SATA hard drive rarely manages above 200MB/s
So it will be slightly slower. However as long as it isn't your OS drive you won't even notice.
if you care about performance, go PCI-E
http://www.newegg.com/Product/Produc...82E16816152105
if you really care, buy a real drive controller...
http://www.newegg.com/Product/Produc...82E16816118100
As your attorney, I advise you to purchase a very fast controller with no top.
http://www.newegg.com/Product/Produc...82E16816151053
do u plan or raiding the hard drives in any way?
look into this if you have a slot
http://www.overclock.net/other-compo...-only-7-a.html
A slight error; SATA II transfer at 3 GB/s or 3000MB/s.
So why not just use an IDE drive? Or even a SATA drive, but adapted to IDE. if it's just for storage as you say, I don't think having it run a little slower would hurt anything.
No, it's 3Gbps or gigabits per second, which is 375MBps or megabytes per second. For some reason this is reported as 300 megabytes. And SATA I was 150MBps.
That's sweet looking.
sweet performing too... that's gigabit ethernet, serial console and mini-sas on the backplane...
SATA II = 3 gigabit/s = 3072 megabit/s = 384 megabyte/s = 300 megabyte/s effective bandwidth
a single SATAII drive can max your PCI bus... if you want performance, do not use PCI controllers...
Gb != GB
There's no such thing as SATA II.
The effective bandwidth is due to the encoding overhead. For every 10 bits of data, only 8 bits are usable.
SATA 3Gbps => 8b/10b encoding => 307.2MB/s
That I do know, but you said MB, not Mb. It's my understanding that an capital B =bits, and lower case b=bytes.
I may be wrong, and if I am, I apologize
Thanks for all the help guys. Unfortunately, it looks like the fastest slot I have available is going to be a PCIeX1 slot. But I have decided that I want to run a Kubuntu drive off of it. So it would be nice if it had a little more speed than a lowly pci slot. I am not planning on running any kind of raid at all on it. I just need the extra slots. Think this one is any good? It's 300mbps so 300/8=37.5megabytes per second.
http://www.buy.com/retail/product.as...ingid=45688740
1 - 16 of 16 Posts
