Have a look @ my overclock to 5.0 each step all i did was bump vcore and multi's running a 5-10 min prime run each time and made it to 5ghz....Its benchable @ 5 but not stable. i also noticed that my vcore jumps under load to 1.498 from the setting of 1.450. awfully close to 1.5v which i understand is the limit before cooking it.Temps are fine never leaving the high 50's underload. Any suggestions would be appreciated.
Heres my settings via bios
Cpu Freq-100.00x50
Dram Freq-1600
Adjust cpu ratio-50
Adjusted cpu freq-5000mhz
Adjust ratio in OS-enabled
Internal Pll overvoltage-enabled
Dram freq-auto
XMP-enabled
Adjusted dram freq-1600
Dramm timing-auto-8-8-8-24/2T
"Advanced Dram config"
Spread spectrum- disabled
Vdroop-low VDroop
cpu core voltage-1.450
current cpu voltage-1.480
Cpu i/o voltage-auto
current i/o-1.352
Dram voltage-auto
current-1.664
System agent voltage-Auto
Current-0.928
Cpu Pll overvoltage-auto
Cpu vref a- all auto
b
c
d-
Active cores-all
Limit cpuid maximum-disabled
Execute disable bit-disabled
Intel virtulization tech-disabled
Power tech-disabled
C1e support-disabled
Overspeed protection-disabled
Cpu Freq-100.00x50
Dram Freq-1600
Adjust cpu ratio-50
Dram freq-auto
XMP-enabled
Vdroop-low VDroop
current i/o-1.352
Dram voltage-auto
current-1.664
Current-0.928
b
c
d-
Active cores-all
Power tech-disabled
