If you've been reading the other sections, you have probably guessed i'm upgrading my system, and i've been having a few odd problems:
On top of the case above the power supply, there is alot of static, and I constantly get electronic shocks from there! Quite sharp some of them are too!
My cpu voltage jumps around like a nutter: 1.37-1.408 most of the time.
My Dimm voltage is always 1 volt higher than what it should be
All the other voltages are slightly higher than they are supposed to be.
It is a 430 watt power supply, with 20amps on the 12v rail.
Do I need to upgrade?
