1 - 20 of 21 Posts
sold my 285. i need a new gpu that can handle codmw2 and l4d2 at max settings 1920x1080 etc.
i was getting atleast 100+ on l4d2 with the 285, need a card that can atleast pull 70+ fps @ 1920x1080.thx and i do want to spend low
Master of Black Snow
Sorry bout the double post. My connection timed out and I didn't post this 1st one but the system did it for me.
Could a mod remove it please?
~Ceadder
ZOTAC GT240 card stats...
ModelZT-20405-10L
Interface
InterfacePCI Express 2.0 x16
Chipset
Chipset ManufacturerNVIDIA
GPUGeForce GT 240
Core Clock600MHz
Shader Clock1460MHz
Stream Processors96
Memory
Effective Memory Clock4000MHz
Memory Size512MB
Memory Interface128-bit
Memory TypeGDDR5
3D API
DirectXDirectX 10.1
OpenGLOpenGL 3.1
Ports
HDMI1 x HDMI
D-SUB1 x D-SUB
DVI1 x DVI
General
Max Resolution2560 x 1600
SLI SupportNo
CoolerWith Fan
System Requirements300-watt power supply recommended
Dual-Link DVI SupportedYes
HDCP ReadyYes
Manufacturer Warranty
PartsLifetime limited
LaborLifetime limited
http://www.newegg.com/Product/Produc...82E16814500146
The 4k Effective Memory Clock is what sold me on this card. Don't ask me for any real life stats cause my bild is not complete and anything I give you would be next to meaningless right now. I'll have my bild up and running in about a month or little longer depending on when my school refund check gets here.
~Ceadder
Originally Posted by tweaker123
want to spend around 150 max. need a budget card.
then the HD5770 would be your best bet.
If you can, wait till the fermis roll out and see how ati reacts to their retail pricing.
I agree with goobergump. With the release of the GTX 4xx series prices are bound to drop. With that said I guess it all depends on how confident/patient you are with the release of the GTX 4xx series. Right now I would suggest a GTS 250 as a budget card.
I have a BFG GTS 250 1GB edition, it runs ~$120 and it is solid GPU. The extra memory helps with higher resolutions (1920x1080) and it runs both L4D2 and CODMW2 easily. That's just my two cents though.
http://www.newegg.com/Product/Produc...-445-_-Product
Good luck with your choice! Keep us posted.
HD 5770 would be your best bet. The GTX 200 seem to be disappearing. The problem with going with a GTX 260 especially if its like a EVGA or XFX is that what if they don't have any more 260s.
Bucking the trend here, but a 4870 would work just fine. And it would be cheaper than a 260, or a few of the other suggestions here.
Discussion Starter · #20 ·
i was thinking of getting a used 4890 for around 150ish?
and can a gtx250 really handle l4d2 at 1920x1080? and maintain good fps?
anything below 80 fps without v-sync looks really choppy and laggy to me.
1 - 20 of 21 Posts
