Man I'm so sad. I et new ram today and my Overclocks sucked, nothing prime stable. I added voltage and still, crash crash crash at anything over 2.3
So I started trying different things but no avail. I then figured, maybe this is all to much for a crap PSU with 13amps on the 12V rail. I plugged the tec, the fans, and the artic cooler all into the 250W PSU I had for the tec from before. Now it's prime stable at 2250Mhz, and ram 1:1. Trying to go higher but looks like PSU is undoubtably the culprit. So What I ned is advice on a new PSU tht can crank to GHz on my chip. Also what voltages are you guys running to hit 2.6??? I've hit 295 fsb beforeat x8 multi, and 2.5Ghz another setting, but niether lasted long. But it did get to windows so I will hold out hope.
Here's what I was thinking:
http://www.ncix.com/products/index.p...Z%20Technology
http://www.ncix.com/products/index.p...tra%20Products
http://www.ncix.com/products/index.p...ufacture=ANTEC
