Need new rad fans!!!
609 Views 11 Replies 5 Participants Last post by  tricecold
Hello everyone, I need some input on new fans that I need for my new Feser TFC 360. I will be using a fan controller will them to be able to control the speed. Anyone got any input. Thanks in advance.
I had these on order but looks like there on back order and need something else.
http://ncix.com/products/?sku=20618&...e=Rexus%20Corp
I was looking at these as a replacement order.
http://ncix.com/products/?sku=16960&...ture=Panasonic
http://ncix.com/products/?sku=20617&...e=Rexus%20Corp
1 - 12 of 12 Posts
Get those high speed panaflos. Still can be silent with the fan controller, and all the airflow you'll ever need when benching.
I have the Feser 360, and I went with a medium speed Yate Loon fan. 3 of them, but they are only 120x25mm. not 38mm. they run at 70CFM and they are pretty quiet, they keep my Quad at 4.0 Ghz idling around 28-30c and load around 38c so they are working pretty good. I'd say get the medium speed Panaflo's but they are sold out. So might as well get the higher speed ones and a fan controller, but I have one of the highest speed one you linked to, and it's way to loud for my taste.. the Fesers work great with medium speed. 50-70cfm fans. so you don't "Need" anything higher, but can if you want.
get the Yate Loon D12SM.. the M is medium, there also is D12SL, and H speeds.
So I should grab these and use my fan controller. But will this fan controller be able to tame these monsters.
Looks like you'll only be able to put one fan on each channel, as it's only 12w per channel, so assuming you only use 4 or less of the fans, you'll be fine.
I'd say get what the guy above said. or a good alternative would be this if you want high speed, Loud fans.
http://ncix.com/products/index.php?s...ufacture=DELTA
or if you want probably one of the best fans you can get for a Radiator in terms of performance.. get a S-Flex
highest speed is 75CFM. and that would be more than enough to keep things cool with a Feser.
http://ncix.com/products/index.php?s...facture=Scythe
or slower
or get these for loud, big fans.
I wouldn't recommend the ultra kaze. They pale in comparison to panaflo, detla, and san ace fans, and won't last near as long. Yes they are cheap, but they've been known to make weird sounds when undervolted and use a sleeve bearing. You get what you pay for.
ok thanks guys I'll keep your considerations in mind when ordering tomorrow. I'm leaning toward these, plus I only need 3 of them. Thanks again guys rep for the help
Thanks for the Rep. Have some yourself.. enjoy building your water loop, I loved doing man. and I'm dreading, yet can't wait to tear it down and add my GPU's to it. lol.
get the panaflo your last post linked to, it's one of the best quality fans you can buy, and the controller will keep it quiet.
What - What - What, are those your core temps, they better not be becuase I may not have a feser 360 but I have a Danger Den Black Ice GT Stealth 240 X-Flow Rad and a MAGICOOL PRO II 240mm RADIATOR, dangerden with 2 pull 2 push Noctua NF-p12 fans and MC rad with at the back of my case working with exhaust fans, and i get at 4.0ghz with q6600 at 1.6vcore 38-42 idle and almost 65-70 on load... Please tell me what I need to do.........
below is my cooling equipment list and a photo
COOLING SYSTEM BELOW
Materials
CPU BLOCK-----------Swiftech Apogeeâ„¢ GTZ Universal CPU Waterblock
GPU BLOCK----------- EK Radeon HD4850 VGA Liquid Cooling Block
RADIATOR-------------Danger Den Black Ice GT Stealth 240 X-Flow Radiator - Red
RADIATOR-------------MAGICOOL PRO II 240mm RADIATOR
RESERVOIR----------- MAGICOOL Magicool 250ML CYLINDER PLEXI RES
PUMP-------------------Swiftech MCP655-Bâ„¢ 12v Water Pump w/ 3/8" Conversion Kit (1200 L/H)
FAN 120mm-----------NOCTUA NF-P12 1300RPM 120mm SILENT CASE FAN
FAN 80mm-------------NOCTUA NNF-R8 SESSİZ 80MM SILENT CASE FAN
HOSES------------------4 M 1/2 HOSE
MODS----------- Logisys Dual 12" Cold Cathode Kit - Blue
PASTE----------- Shin-Etsu X-23-7762 Silicone Thermal Compound - 1g
COOLANT----------- THERMALTAKE COOLANT 1000CC ULTRA VIOLET
please help
Maybe you should start by getting those kinks out near your res. Those are massive flow killers!
I now about the kinks, I will fix them asap also but I dont think they really cause 10 degrees of celcius diffrence.
1 - 12 of 12 Posts
