1 - 10 of 10 Posts
Hey guys, where can i get this seal?
universal CPU water block: EK-Supreme LTX UNI CSQ 2013
It would not fit in the grove of the plexi peice, it was to long and would not seat correctly, it was to long so i cut it and took some off and tried melting it back together with a small torch but it just burned, no melting.
Where may i find this seal?
I'm thinking it will take the proper shape when stuffed into the groove. As long as length is correct should be OK...
I ordered a few of them, they are a $1 each.
ciarlatano seems confident, if dont fit, figure something out.
( ━☞´◔‿ゝ◔`)━ ☞
The o-ring tends to be slightly bigger than the grooves because it expands when compressed to provide the proper seal.
Next time try putting the o-ring in the freezer for a little bit so that it can help "shrink" and be easier to put back into the groove.
I stuck in a glass of ice water for about 10 minutes and it did not shrink well I'll try the freezer but I was even thinking gluing it. I don't know how EK got it in there because that thing fought me for about 45 minutes I tried my fingers were hurting.
( ━☞´◔‿ゝ◔`)━ ☞
Glue does work apparently. That's one tip I learned from people who make custom blocks or distros is to cut the o-ring a bit shorter and super glue the snipped ends together.
Definitely let the superglue dry/cure before attempting to put it back into the grooves and leak test the block/distro before you install.
Discussion Starter · #9 ·
Super glue wont cause any bacteria or scum or harm the water cooling additives or vice versa and how about running blitz part 2? Will blitz part 2 eat the glue etc?
What brand is best for super glue, the green capped one? cant remember the name.
( ━☞´◔‿ゝ◔`)━ ☞
I haven't personally tried it myself. I think just about any super glue works as long as you're not overusing it past the o-ring diameter.
Supergluing o-rings has been a common practice in the automotive industry for decades and those parts tend to see much higher pressure and temperatures than our computers.
1 - 10 of 10 Posts
