Need opinions on AMD build
301 9
yes, I might Be switching over to the other side of the fence, i just need opinions.
Note: this is Newegg.CA
Opinons welcome and open
1 - 10 of 10 Posts
i have an idea, where we set-up a section with build recomendations, like blueprints for certain buget of people
and thanks Penicilyn
· Efficiencycionado
· Goodbye
Originally Posted by gerikoh View Post
nice build.
but you can get a cheaper board, for the same performance
like these:
http://www.newegg.ca/Product/Product...82E16813130191
http://www.newegg.ca/Product/Product...82E16813186150
or if you're a fan of asus:
http://www.newegg.ca/Product/Product...82E16813131366
That last one, while a sweet board requires DDR3 which I think is a major plus.
I would recommend this RAM.
Patriot 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Produc...82E16820220278
$66
· Premium Member
Direct Canada is way cheaper and they don't charge shipping for orders over $300 and they don't charge pst if you don't live in BC. $984.55 CAD with a 4870 card instead of a 4830. Just add PST and you are done. They didn't have your case though so I had to substitute. Newegg.ca has better selection but their prices suck.
Looks good, i wouldn't go for shapire or gskill tho, but if you like them, very nice build.
*you could get more out of your 720BE on an am3 board/ddr3 imo, but that affects price a lot. Nice build for the budget you got there.
· Premium Member
I like Dman's suggestion.
The parts look awesome in either list.
As far as a cooler goes, just get a Noctua
1 - 10 of 10 Posts
