Hi!
I just happened to get an Antec Three Hundred for a very cheap price, and since I'm planning on a new build anyway I thought of asking the more experienced members here for any tips or criticism on my plans for my air cooling solution (not necessarily mine since it seems to be very common. Anyway..).
Specs of the build:
Gigabyte GA-EX58-UD3R
Intel i7 920
3 x 1GB Kingston HyperX 1600MHz DDR3
Gigabyte 9800GT with Zalman's cooler
Cooler Master Silent Pro 500W (thanks Re-Evolution!)
Now for the cooling:
Two Scythe Ultra Kaze 1000rpm's taking air in from the front side.
One Ultra Kaze 1000rpm in the back and a 140mm Spire on the top as exhaust.
For CPU cooling I was planning to get me a Noctua NH-U12P SE1366 or OCZ Vendetta II (if the LGA1366 brackets are to be found). For whichever it might be I'd aim either a push-pull or singe push fan blowing to the direction of either one of the exhausts.
Now of course I value silence over overclockability (especially because I'll be overclocking the 920 only ever so slightly), so I might go with the Noctua NF-P12's with U.L.N.A's if I get the extra dough, instead of Scythes. Silence is golden and duct tape is silver and all that jazz. Which one do you recommend? I'm a bit worried about getting too loud fans, since my present PSU fan is giving my right ear some tinnitus, I suppose.
Would a white paint + clear laquer on the body and black paint on the internals harm conductivity too much, considering my level of OCing (few hundred MHz?)?
Whilst thinking about it I quickly found myself modeling the 300 and I came up with this render:
I was thinking of calling it Fjällräven (mountain fox in Swedish)
Oh, and for the PSU I was considering Cooler Master Real Power M520 Silent Pro 500W (loving dem modular wires), which in this case (heh) would be put to the bottom, from where it would suck some air from under the GPU and blow it out, I suppose?
Here comes the crude drawing to aid my nonsensical babbling:
Now how about isolating the CPU by giving it it's own ventilation duct (I've seen people do it and get better results)? Also, there are these so called "BeamAir" systems from Nexus, which are sold as being able to focus the airflow better. I was thinking that maybe I should get one of these for the lower fan in order to blow the air more efficiently onto the GPU.
They look something like this, which in my opinion seem like bit of a hindrance to the airflow, eating away precious CFM (especially with low noise fans am I right?)
Sorry if the structure of the text is confusing, and thanks for reading all of it!
