1 - 9 of 9 Posts
Stealin Yer Sammich!
  1. Location. USA
  2. If not in the US, links to stores in your country.
  3. Budget! Set a prefered price and an absolute maximum if you can. $75-$100
  4. Wattage needed, if you're not sure then that's fine but make sure to give us the details to #5! 550w-750w
  5. What will you be powering? Include as much detail as possible.
    Phenom II X6 1090T processor. Stock.
    2x8GB Avexir 1600Mhz RAM Sticks
    4 HDD and 1 SSD Drive
    1x Asus Strix1050Ti powered by a 6pin external power connector
    1x EVGA GTX 770 4GB Classified(2x 8 pin connectors
  6. Modular cables? Non-modular/semi-modular/fully modular. Full Modular Please. Will consider semi modular
  7. Number of PCIe cables needed.
  8. Any other requirements. For example size, flat cables, ATX/SFX/TFX etc. Not that I can think of.
Thanks!
Eh, Wha?
Seasonic focus / focus+
Senior OCN Member
⤷ αC
Currently the Seasonic Focus Plus Gold on sale are the best bets, especially with 10 year warranty throughout the range.
It seems most of the EVGA / Corsair units are still more expensive , but a Corsair RMx or G2 unit from EVGA would work alright as well (those are also 10 year warranty , although EVGA only has 7 years on their 550 and 650W ones).
Phenom II x6 1090T is only going to be around 200W full system load (despite TDP 125W) , GTX 1050 TI is max 75W generally, GTX 770 about 200W. Seasonic's conservative power calculator has your system at 576W when including disk drives, gaming keyboard, fans, etc.
Focus Plus Gold 650W $70 ($20 MIR): https://www.newegg.com/Product/Product.aspx?Item=N82E16817151186
Focus Plus Gold 750W $80 ($20 MIR): https://www.amazon.com/dp/B073GWKDVM/
Focus Plus Gold 850W $100 ($20 MIR): https://www.newegg.com/Product/Product.aspx?Item=N82E16817151188
Overclocking Enthusiast
Senior OCN Member
1 - 9 of 9 Posts
