Hmm, what mobo do you have?
Gigabyte has a cpu support list, and it shows what processors use.
Also, all the 900 series use the same cores, and from what i understand are just the ones that couldnt be made to the higher models specs... could be wrong on that particuular part
but check the cpu support list and see whats on there for sure, hopefully someone else can help ya better
also yeah i have the same chip as you, b00 higest i could get it STABLE i 3.17 on air @1.45v , one guy got it to 3.45 on water @ 1.45 or maby 1.5 volts.
