Need recommendation for new case.
870 Views 21 Replies 15 Participants Last post by  Jolting
I would perfer it to be black and 1 other color or just black. I perfer it to have fans without leds due to me wanting to put in some cathodes with a switch. If the leds can be turned off that would work as well. Price ~$100 USD. I don't use watercooling so lack of spots for rads is ok. I doubt I will be using watercooling any time soon its just too much money.
I plan on trying to put the cathodes on a powersource that will work even without the powersupply being active so that I can turn on the cathodes to work on the computer when needed (If possible). Probably would make it so I just switch over 1 cable to my external power source for the ide hdds to make the lights turn on.
1 - 20 of 22 Posts
get some black paint and use a cardboard box, or a Antec or Coolmaster
Hi.
This Chieftec mid-tower is a decent contender for your needs.
If you want a full-tower, then This Chieftec might do.
This 2-tone Gigabyte might also be nice.
Although I have no experience with This X-Clio, I find it to be intriguing...
for a pretty decent mid tower case which from reviews has a good amount of room as well, look into the Coolermaster CM-690.
http://www.coolermaster.com/products...detail&id=2908
It has the option of having a window or not but the windowed panel is sold separate. The front fan is blue which I know you said you didn't want a led fan but it is is behind the drive bays so much of the light does not show through. I had it in the running for my current build but opted for the HAf 932 instead.
I second this, the refurbished 690 can be had at around $45, and side panel with window is about $25.
If you don't like the front LED fan just swap it out with one that doesn't have any
. All in all you probably won't pay over $100 this way, even WITH the CCFL's you plan on buying.
Cooler Master 690! I love my case.
After consideration I will probably grab the 690. I may replace the front fan with a pitch black fan without leds or maybe one of those amazing fans that XClio sells. Does anyone know what the biggest fan you can put on the front of a 690 is. Would a 140mm fit? I would also grab a side window with it.
Heres link to smallest amazing fan. http://www.newegg.com/Product/Produc...82E16835234002
That or I would grab a XClio Wind Tunnel http://www.newegg.com/Product/Produc...82E16811103011 and skip the cathodes.
Edit: Buying a 690 refurb from CM has a $32 shipping cost along with the side panel would toss me over $100 after all. I don't see the free shipping on the 590. Says it comes out to 84.
I personally love my case, its a great case, black and silver with window of course.
Only downside is One rear 120mm and one front 80mm, But I havnt noticed any issues, and I'm sure others have used this thing before
Coolermaster Centurion 5
Awesome Case and under budget, it runs my system rather cool actully.
I say CM 690, all the room you need, great case, I love mine!
yes, this.
for $100, you can get the 690 and replace the fans with yates... and have enough left over for a burrito or something.
Originally Posted by trogalicious
yes, this.
If you DO get a burrito....make sure to post pics!
I would never get a burrito they taste bad.
What burritos have you been eating?!
Also if you get the yates, then get a fan controller, they are noisy.
1 - 20 of 22 Posts
