1 - 3 of 3 Posts
I f'd up and pulled my router of the shelf when I snagged the wires. I have since fixed the wires so this cant be repeated but now I need replacement antennas for my Asus AC68U.
Wouldn't mind a little more range but I know buying 1568db gain antenna's is not going to let me get better signal in the next room.
Should I just try to find some asus ones on ebay or is there another brand that will work well?
Thanks Guys
Originally Posted by Jiryama View Post
Personally i would forego the stock replacements, I would pick up these wireless Antennas from Amazon.
This is actually an upgrade from the stock Antennas and you should see a small bump in the performance. Only $20 and free shipping, it's a fairly good buy.
Awesome, Thank you sir.
1 - 3 of 3 Posts
