1 - 12 of 12 Posts
Hello I might buy a new MB but I am wondering which of these would be a better deal. I am looking for the best bang for the buck but I am looking for top notch performance and OCing ability.<br />
<br />
1. <a href="http://cgi.ebay.com/B3031-New-MSI-865g-neo2-pls-ms-6728-p4-motherboard_W0QQitemZ120041186433QQihZ002QQcategoryZ44943QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.com/B3031-New-MSI-86...QQcmdZViewItem</a><br />
<br />
2. As long as the price stay resonable... <a href="http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220037529012&fromMakeTrack=true" target="_blank">http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true</a><br />
<br />
3. I have heard good OC results with this board... <a href="http://cgi.ebay.com/ABIT-VT7-SOCKET-478-MOTHERBOARD_W0QQitemZ190041355201QQihZ009QQcategoryZ80157QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting" target="_blank">http://cgi.ebay.com/ABIT-VT7-SOCKET-...ayphotohosting</a><br />
<br />
4. Another one from the 478 appreciation thread... <a href="http://cgi.ebay.com/ABIT-IS7-Intel-865PE-Socket-478-Motherboard_W0QQitemZ170037426626QQihZ007QQcategoryZ80157QQssPageNameZWDVWQQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.com/ABIT-IS7-Intel-8...QQcmdZViewItem</a><br />
<br />
I dont need a MB as my Asus P4P800 SE works very good but the SATA controller is broke so I am using a PCI SATA card which limits performance. Also I have a bad vdroop problem limiting my OC to 3.6 Max stable and 3.8 MAX bootable. <br />
<br />
Thanks guys for the help and have a good one.
Abit IC7-G all the way. I love it. It is a great board! Plenty of V-mods too if you are into that stuff. Also look at the ASUS P4P800SE since it is also one of the best S478 boards.
I already have a P4P800 SE and like I said ythe SATA controller is broke, so I want not need a new MB. My ultimate goal is a 1gig OC I can get there with this Asus but it has a bad Vdroop and I dont want to give a whack at doing the droopmod as I almost fried the MB already. So like I said the best bang for the buck.
i have a P4C800 E Deluxe, not too much v droop, <br />
dont remember exact ammount, its ben a few months since i used it<br />
<br />
works BEAUTIFULY<br />
<br />
but the ABIT IC7-G is amazing for 478
Discussion Starter #5
Ok I have 2 for the IC7 but what about the MSI and the other MB. I hope to get a new MB either way just incase for a backup as I may do the droop mod and if I brake my MB I can rest well knowing I have a backup. Also is the IC7 better than my P4P800SE?
ASUS P4P800-E DLX is the best for socket 478 outhere.
Discussion Starter #7
Oh come on now we all know thats not true considering the P4C800 with the 875 chipset is better. The biggest difference between the e dlx and my SE is the SATA slots. I think I may get the IC7, or the MSI neo2 pls
<div>Originally Posted by <strong>Villainstone</strong></div>
<div style="font-style:italic;">Oh come on now we all know thats not true considering the P4C800 with the 875 chipset is better. The biggest difference between the e dlx and my SE is the SATA slots. I think I may get the IC7, or the MSI neo2 pls</div>
</td>
</tr></table></div>
It's just the PAT enabled on default that may be the difference between the 875 and 865. However, I find no creditable performance different when PAT enable or not (it's also noted that PAT might cause instability).<br><br>
Yes, and the EDLX has 2 extra SATA slot on Promisetm SATA controller.
The IC7 is the best period, lots of OCing options, vmod options, very popular board! (owned 3 myself). The IS7 is a downstep from that, probably a bit better OCer than the MSI board, though the MSI board is a good bang for the buck, if that's what your looking for.
Discussion Starter #10
TY Wowza that is the kind of feedback I was looking for. I was wondering about each MB and which is the best for the cash I will be spending. I will shoot for the IC7 but I can settle for the MSI if it comes to that. Basically the only thing that would stop me is cash+demand, I don't need it bad enough to spend lots of cash.
ill part with my P4C800 Deluxe for ~70?
Discussion Starter #12
Sounds good I just sent a PM for extra info so take a look. Thanks for offering your MB I am intrested so I hope we can work something out. If its not going anywhere any time soon I would like to make two payments if at all possible.
1 - 12 of 12 Posts
