1 - 8 of 8 Posts
the default changed to notepad and i dont know how to change it back
cant open rededit, cmd or system restore or anything at all. not sure how i managed to get firefox going to post this
· What should be here ?
1. Open Command Prompt by typing cmd in RUN dialog box.
2. Now provide following command:
cd\windows
3. It'll activate Windows folder. Now provide following command to open Registry Editor:
regedit
4. Now goto following key:
HKEY_CLASSES_ROOT\.exe
In right-side pane, change value of Default key to exefile
5. Now goto:
HKEY_CLASSES_ROOT\exefile\shell\open\com…
In right-side pane, change value of Default key to:
"%1" %*
6. Thats it. Now exit Registry Editor and restart your Windows. Now you should be able to open EXE files without any problem.
its not regedit, type cmd in the run (win+"R") and the command prompt would launch
if you can launch command from task manager, do so and then follow from step 2
Discussion Starter · #8 ·
Ahhhhh
Gold star to GeForce
I downloaded the file and merged the reg file for exe and done :)
I can relax now
Also thx to huzz for trying but as i said cmd and regedit are exe files so couldn't be opened to change the reg manually
1 - 8 of 8 Posts
