Alright i will be moving soon and i just got into the whole HD Phase. i just bought a new tv and want to hook up my computer from a room to my living room its approximately 40 feet i hvent really measured it yet but i estimate its around 30-50 feet.
During the past few days ive been searching the net for solutions
Solution #1
Running Dual Cat6e Cables and two 3-6 Feet HDMI cables
Items needed
HDMI over CAT5E / CAT6 Extender Wall Plate (Pair) - Single Port (1P) - White $18.15
CAT6A STP(Shielded Twist Pair) 50FT Molded Cable - Blue $13.47
High Speed HDMI 1.3a Category 2 Certified CL2 Rated (In-Wall Installation) Cable (24AWG) w/ Net Jacket - 6ft (Gold Plated Connectors) $8.30
Total Setup Cost $61.69 length - 62FEET
im debating whether to have longer hdmi and shorter Cat6 cables or Longer cat 6 shorter Hdmi 0.0
Solution #2
HDMI Silver-Plated Copper CL2 Rated (For In-Wall Installation) Cable (22AWG) - 50ft (Gold Plated Connectors) $87.04
Total setup cost $87.04
Hmm worried about quality and signal lost at that length 0.0 heard alot of bad things about it
Solution #3
HDMI Booster/EQ Unit Look At the bottom page $45
High Speed HDMI 1.3a Category 2 Certified Silver-Plated Copper CL2 Rated (For In-Wall Installation) Cable (22AWG) - 25ft (Gold Plated Connectors) $48.11
Total Setup Cost $141.22 50 Feet
Hmm im considering about this one but im not sure how does an hdmi booster work really 0.0 do u just connect the two separate hdmi cables together and wala? or does it work like connect an 6 ft hdmi cable to booster and the then connect an 40 foot hdmi cable to your tv
BTW im using these connections to connect to my computer the video card has an HDMI Port
ive read only one success from JamSter
http://www.overclock.net/monitors-di...0p-pics-6.html
hm i was also plannign to just buy solution#1 first and if it doesnt work i could use the cat6 cable for my verizon dsl. 0.0 i could use those cat6 cables for my dsl right? lol
I was considering solution #3 base on this one comment
does this work with an ati video card?
i read this on the reviews
Does NOT work with ATI video cards
I purchased this along with 2 50ft CAT6 cables, and they worked perfectly with my XBOX 360. However, I bought this item with the intent to use it with my ATI video card's DVI/HDMI adapter, thus allowing me to watch video from my PC to my TV.
Unfortunately, I was never able to get said combination to work. I spent 9 hours trying various combinations of drivers, settings, cables, etc to hopefully make this work. I was not able to get a picture to show, let alone sound. After a 1hr long conversation with tech support here on Monoprice, we determined that these wallplates are simply not compatible with the video cards. I know it's not the video card (Sapphire 4890) either, since I was able to get a picture and sound when hooked up directly with an HDMI cable.
So yeah, this product is great for extending something like a console or set-top box, but steer clear if you want to use this with your video card.
Solution #1
Items needed
Solution #2
Solution #3
