1 - 7 of 7 Posts
hey guys i received my dell xps today and i wanted to set it up with the wireless internet connection but it doesnt work. I receive signal and wen i connect it says minimal or no connectivity ! can someone help me plz?<br>
thank you
first off u bought a dell!!!!!! im sure u could have built a better computer for the same price, n e way sorry about being anti store bought, ok dell wireless is trickey to set up try finding a reset ip adress button or repair connection button or run the network set up wizzard, it needs a little bit of set up b 4 it work like it should
Ohh XPS, Which one?
i told u above, run internet set up wizzard and if that dosent work look for the repair internet connection button or reset ip adress button
is the router in its distance? and a dell.....?sometimes u get it saying u have the connection, once u go to get into the connection, iits gone, thats sometimes because the distance is to great, or not enough bandwith....sometimes
<tr>
<div>
Originally Posted by <strong>nemesis975</strong>
</div>
<div style="font-style:italic">i told u above, run internet set up wizzard and if that dosent work look for the repair internet connection button or reset ip adress button</div>
</td>
</tr>
</table>
</div>i agree, network set-up, choose existing broadband connection, and you're done after you have "enabled" the wireless lan, remember to do so...
1 - 7 of 7 Posts
