I'm hoping you guys can help me out here.
I have a H70 cooler on my 2600k. Right now it's set auto overclock through the ASUS BIOS to 4.5ghz. When running at that speed it looks like my voltage is at 1.304.
After running it for 15 minutes or so my temps are between 70-74. Isn't this a bit high? My idle temps are fine, usually between 28-34C. I have re-seated the pump, I have changed the direction of the fans on the radiator, yet my temps are still around that range when running at 4.5ghz.
Is it the voltage that is causing these temps?
