1 - 7 of 7 Posts
I have this 2TB External Fantom Green Drive http://www.fantomdrives.com/products/greendrive.htm it has one of these: http://www.newegg.com/Product/Produc...82E16822152202
and currently I'm building a new computer that will mostly be used for gaming.
this is the motherboard I'll be using: http://www.newegg.com/Product/Produc...82E16813128494
I was wondering if it is wise to convert the external hard drive internal and buy a SSD for OS and a few selected games.
It would be either I do as mentioned above or buy a new http://www.newegg.com/Product/Produc...82E16822136533
* budget for an SSD would be @ ~100 bucks
Thanks in advanced for any help provided.
WD Black is going to be way faster than a 5400RPM last-gen drive. (F4 2TB is the newest 5400RPM 2TB drive that Samsung produced.)
I don't like running an OS or games off "Green" drives. But if it increases what you can spend on your SSD... I suppose it's an option.
I support your decision to switch the OS drive to an ssd but loading games onto it doesn't really make sense. The most you'll see is a slight jump in load times and that is all. The second drive for storage can be a slow 5400 if you wish
Sent from my HTC Incredible S using Tapatalk
Not having a good time
It is a great Idea although as said before: It's better to get a 7200Rpm or higher for secondary storage but If you want to get a Better SSD with more space/speed It'll be a great Idea.
Actually I run a SSD and load times in games are actually a lot faster
C300/M4 or any Intel SSDs are great. Also, now that most of the firmware issues are worked out, Sandforce SSDs (OCZ, Corsair, Mushkin, etc.) are another option.
1 - 7 of 7 Posts
