Need some assistance
444 Views 9 Replies 4 Participants Last post by  Toan
so recently just out of the blue my computer would just randomly lock up and the screen would turn into this screen with crazy colored lines everywhere and they flicker like crazy. i think its my video cards, should i RMA?
1 - 10 of 10 Posts
100% random, or when you're doing GPU intensive things?
Try each card one at a time, stressing them the hell out - monitor temps, of course - to rule out it being a single card issue.
Hi.
Have you tried to remove your Video Drivers, clean, and then re-install them? (newest version if you already haven't).
Are you overclocked? If so, are you stable?
it just happened to me right after i put my PW in to log into windows just randomly happens
i tried ruling out each card and they both are fine separately but when in xfire they go crazy with the colors
i am using the most up to date version of CCC so i assume its not the drivers.
+1
Use driver sweeper to remover your current drivers, then download the latest ones and install those.
You haven't overclocked your graphics card at all, have you? Make sure you monitor the temperatures to see if it's getting ridiculously hot.
Hi.
yea went to safe mode, took out the drivers, put new ones in and no im not OC'd, im 100% stock settings except for the fan speeds on the 5770s
card 1 reads 37c
card 2 reads 34c
both at 65% fan speeds
Hi.
Clean the drivers anyway to be sure. Remove any overclocks, of course. Are you monitoring temps when this happens? CF/SLI can make some crazy temps if airflow is poor - one card venting hot air into the other card's intake, that sorta stuff.
yea quick posting makes it hard to keep up to who's saying what lol but anyways i did do driver sweeper and all in safe mode. and i do have it in CF but there is alot of space between each card and i do have good airflow. it happened once after that cleanup and now it seems to be ok. both cards are around 35c so idk what it could be
ok so i had both cards at x16 for at least a month or 2 and when i put them back in x8 configuration its fine. any thoughts?
guess i spoke too soon
the x8 config lasted alot longer this time about 2 hours and i even played mw2 with no problems at all but once i left the game and went back to the desktop to finish my download a few minutes later my screen started to slowly "pixelate" until i couldnt even see anything on my screen except for millions of little red/white dots then it just restarts on its own.
these are the errors i get:
(made them different colors for easy reading)
Source
Windows
Summary
Shut down unexpectedly
Date
‎12/‎1/‎2009 10:33 PM
Status
Not reported
Problem signature
Problem Event Name:BlueScreen
OS Version:6.1.7100.2.0.0.256.1
Locale ID:1033
Extra information about the problem
BCCode:1e
BCP1:FFFFFFFFC0000005
BCP2:FFFFF8800422D7CF
BCP3:0000000000000000
BCP4:FFFFFFFFFFFFFFFF
OS Version:6_1_7100
Service Pack:0_0
Product:256_1
Source
Windows
Summary
Date
‎12/‎1/‎2009 10:50 PM
Status
Not reported
Problem signature
Locale ID:1033
BCCode:d1
BCP1:0000000000007FFE
BCP2:0000000000000002
BCP3:0000000000000001
BCP4:FFFFF8800542D7CF
OS Version:6_1_7100
Service Pack:0_0
Product:256_1
Source
Windows
Summary
Date
‎12/‎2/‎2009 1:36 AM
Status
Not reported
Problem signature
Locale ID:1033
Files that help describe the problem
120209-22651-01.dmp
sysdata.xml
WERInternalMetadata.xml
BCCode:3d
BCP1:FFFFF880009B0020
BCP2:0000000000000000
BCP4:FFFFF880043A27CF
OS Version:6_1_7100
Service Pack:0_0
Product:256_1
1 - 10 of 10 Posts
