Need some direction
454 Views 15 Replies 3 Participants Last post by  Kemer
Buying 2 new 92mm fans for my cpu, and was just wondering why some of the fans on Newegg specify some of them as 3 pin Molex and others that are exactly the same just say 3 pin?
Im just looking for a standard fan that my bios will control on its own.
Ie- http://www.newegg.com/Product/Produc...-004-_-Product
Case fan i currently own. http://images.google.com/imgres?imgu...a%3DN%26um%3D1
1 - 16 of 16 Posts
They mean the same thing, and can be controlled by the mobo.
I was told that buying just any case fan with a Black, red, Yellow wire combo could ruin my MoBo and i would need to find a Fan that had a Black, red, Blue wiring. Is this true or can i run any case fan to my MoBo/Cpu?
I'm fairly certain wire color does not matter, it varies by manufacturer.
Also to answer your original question. 3 pin molex is powered direct from the power supply and runs full speed always(unless connected to fan controller or has switch attached). 3 pin is powered from small 3 pin connectors off the motherboard and can be controlled via BIOS or software utilities generally.
Edit: added more info
Hmmm mixed answers... thank you for the replies. Newegg shows 3 pin connection to the mother board on there picture but says its 3 pin Molex. Im confused.
It may take some time to get the fans i need.
PSUs have no 3 pin connector.... 4 pin molex is where the fans run at full speed.
So can i safely run a case fan off of my MoBo for my CPU without causing problems?
Yes... Fans are fans, there's really no distinct difference between CPU fan and case fan.
Unless you're using one of those high voltage Sans Ace fans or something.
Ok 1 more questions for you xHassassin. Im pretty sure running 2 fans on my heat sink wont be a prob watt wise because im not running that much on my Mobo as it is, but i cant find what my Max watt is for my Mobo. Heres a layout of mine http://h10025.www1.hp.com/ewfrf/wc/d...s&lc=en&dlc=en. what do you think?
I plan on running 1 fan from my system fan 3 pin connection to heatsink and the other off of the cpu 3 pin connection.
Wait.. You're putting two fans on the same HSF?
That's not going to do anything except screw up the airflow and make it worse off.
let me explain. I recently changed my Pc case to a antec 900-2. The case comes with 4 fans in it already. I had to unplug my old 92mm case fan which ran to the system fan 3 pin connectors because there was no room. Now i get a sys fan error, so i thought buying a heatsink that allowed 2 fans would solve the problem. 1 fan pushes air through heatsink other pulls and goes right out my 120mm case fan.
Oh, yeah pull pull configuration works. I thought you were going to stack them on top of each other.
Haha
that would be extemely funny to see though!!
1 - 16 of 16 Posts
