Hi, I just got a new case Corsair 760T and I thought about getting a an AIO cooler ( H105 or 110) but I been reading and looking and decided to do a custom loop. It's going to be a "simple" loop just my cpu and gpu. After a long search I found a block for my MSI R7970 lightning card, will be using a EK-FC7970 Lightning - Acetal+Nickel cooler for it along with either:
A) http://www.performance-pcs.com/hot-xspc-raystorm-d5-photon-ax360-watercooling-kit.html
But my main question what's the best tubing size ? As the kit comes with a choice of 3 tube sizes,7/16" x 5/8",
1/2" x 3/4",3/8" x 5/8", and will the kit be ok with the the gpu block? tia..
