Originally Posted by vinaypro
Thankx..
Is ther any way of knowing the specs of the stock fan? Size specs(LxWxH) and the noise level etc..
4.25" L x 2.75" H x 3.80" W
The above cooler looks good but doesn't it dissipate the hot air into the case rather than directly out of the case thru the vent..?
Since i m using a slim case wont it be a bad idea..?
Both stock cooler, and that cooler put air into the case.
You are using a low power CPU though. So it's not going to generate much heat. Though, if you want a smaller fan,
Silverstone's NT07 is the smallest you get.
Your best option is to pick up a PCI Slot Blower, like
this Rosewill.
