Need some new memory.
328 Views 2 Replies 3 Participants Last post by  whataboutbob?
Im in the market for some new memory, as you can see by my rig its alittle mispaired at the moment,any ideas on what i should get?
1 - 3 of 3 Posts
Both the OCZ 2x1GB Platinum series http://www.newegg.com/Product/Produc...82E16820227210
and the G-Skill DDR500 2X1GB http://www.newegg.com/Product/Produc...82E16820231021
have recieved great reviews and everyone raves about them. Both should work fine with your mobo. They are both about the same price too just depends on wether you want more bandwidth or tighter timings though the OCZ has been known to overclock to close to DDR500 on stock timings.
Thats just me though...
i hafta totally agree w/ what frogmazog said. both sets will do you fine and are in pretty much the same price range. i personally have the ocz's and am very happy w/ their performance.
at 2-3-2-5 i can only get them to 205, but if i loosen it up to 2.5-3-2-5 it will hit 230 and be stable. however, thats as high as i can get them to go even w/ loosen timings and more power. but, thats plenty fast enough for me!
i think either set will be perfect for u. just depends on if you want a really hi oc, or really tight timings.
1 - 3 of 3 Posts
