Ignore the "onfo" part, looking for info I assure you.
Hey all was running prime 95 but got an error about 68 minutes in on one core. The bit about a rounding error of .5 instead of.4 etc.
I was testing it unlocked at 3.6Ghz with voltage up .100V to 1.425V.
Bus speed was still 200mhz and I just changed the multiplier to 18.
Any thoughts on what I should try changing to get it stable at 3.6? In games and such it's fine and it doesn't get too hot in prime95 (max 54-55C)
Also those numbers are with everest which overestimates the temp compared to cpu-z and pc wizard by around 5-6C. (I know this from comparing the temps in dual core when I have the thermal diode reading.)
Is 1.425V the maximum safe voltage for these unlocked chips? And should I try changing the bus speed to something else first and backing down the multiplier?
Sorry for the noobish questions, this is my first real build.
