1 - 3 of 3 Posts
Hai,<br />
<br />
just some questions, coz i try to overclock my pc but some **** doesnt work so good.<br />
<br />
I'll say my system first:<br />
<br />
Intel Pentium 4 3.0 GHz (E i think)<br />
Asus P4C800-E-Deluxe<br />
nVidia Geforce 6800GT<br />
2 times Corsair TwinX 1024 C2 PC3200 (so 4 times 512mb)<br />
<br />
I also got decent air cooling,<br />
so i get to overclock my cpu @ 3.6 GHz everything stable and all but then my FSB<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />RAM ratio is 5:4 and my mem only runs at 192 Mhz so lower then the standard.<br />
<br />
I tried to overclock my mem it didnt work at all,<br />
when i try FSB<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />RAM ratio 1:1 then when i overclock to FSB 205 my mem is already unstable, and at 210 it doesnt even start up windows, i tried to change voltages of mem and timings but nothing.<br />
<br />
So if some1 can help me with tips or sumtin, it would be great, thx alot.
Set the ram back to stock and run some memtest to see if the ram is operating correctly at stock speeds. <a href="http://www.memtest.org/download/1.65/memtest86+-1.65.iso.zip" target="_blank">Download this program</a> to determin if the ram is failing or not. Also what PSU are you running and what "air cooling" have a link for the ram you have?? And this is 4x512 sticks right not 2x1024??
Im running on a 470W Akasa Power supply, this is the cpu aircooling block i have <a href="http://www.compu-square.be/product_fotos/7c60717a-2054-4134-92ff-4c535e5ea595.jpg" target="_blank">http://www.compu-square.be/product_f...535e5ea595.jpg</a><br />
<br />
And i have a NZXT Lexa classic casing with some fans; <a href="http://www.nzxt.com/products/lexa/" target="_blank">http://www.nzxt.com/products/lexa/</a><br />
<br />
It is indeed 4x 512 i have, coz i had only 2x 512 first then upgraded to 2 Gig.<br />
2 times Corsair TwinX 1024 C2 XMS (standard clocks 2-3-3-6) PC3200<br />
<br />
Ok i'll check for the programs soon, im short of time now.<br />
<br />
Thx
1 - 3 of 3 Posts
