as you can see from my sig rig, i run a evga 560 ti (448) . i have a 28'' monitor thats does 1920 x 1200 and i really dont want to cut down the resolution on my games to gain a couple fps. i have a budget of $350 , but would like to spead less if possible. i think all i really need is some more vram? here's some cards i've been looking at...
msi 7870 hawk
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127681
sapphire 7870 xt
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202024
i have thought about these two cards,but i'm trying not to spend my whole budget.
evga 660 ti 3 gig ftw (not sure this card can even use 3 gig)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130817
sapphire 7950 boost
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026
all i really need is playable fps without breaking the bank. can a 7870 get me there? or will i need one of the stronger cards?
msi 7870 hawk
sapphire 7870 xt
sapphire 7950 boost
