1 - 3 of 3 Posts
I want to get a water cooling system for my new computer. The specs for it are below and i want to know if there are any good cooling systems (that i dont haev to spend days working on) out there for less than $200. Any suggestions?
SNERP!!!
HERE is a link to my "you're a cheap bastard, but you can still have custom watercooling"
I forgot to list a relay switch for the pump which would add $10-25 depending on what switch you went with. You might be better off with the Danger Den D5 for $75 it just depends on how much you want to spend.
I think that is a nice start for a system and it can also be upgraded to have a video card block on it. Post more questions if you have them
1 - 3 of 3 Posts
