1 - 4 of 4 Posts
Can anyone tell me or measure and tell me the distance between the mounting holes for the Thermalright TY-150? I believe all sides are equal. Thank you!
PS: i dont own one, but id like to buy one and need the mounting hole distances.
EDIT: I just found a German site and got my answer. Sides are not equal, one side is 125mm the other 105.
I need a fan for my Lian Li PC-A05FNB top fan hole. Would appreciate any suggestions.
400
Originally Posted by smash_mouth01 View Post
It apparently has 140mm mounting holes..
I stand corrected, it has both depending on orientation...
This may help
So I am guessing that no it won't fit any standard 120 or 140 hole spacing.
Yep thanks for clearing that out.
1 - 4 of 4 Posts
