1 - 4 of 4 Posts
Hello ladies and gentlemen.
I need to replace the four screws that hold together my waterblock. The block is exactly this: https://www.ekwb.com/shop/ek-supremacy-evo-elite-edition-intel-2011-3
I would like to know the exact size of the screw if someone here knows it, because it would be rather difficult now for me to disassemble me watercooling right now. Apart from that I imagine that the replacement screws must also be nickel plated like the old ones. Is that right? Would using non nickel plated screws damage the block's base surface? Please let me know and if you have a link to suggest I would prefer Ebay because I live in Greece.
Thanks a lot!
Shooting down fallacies
They do not need to be nickel plated, but you will have to match the head's countersink size along with the overall size so they sit flush. Unfortunately, I do not know the sizing, but EK customer service does.
Thanks for your immediate reply my friend ciarlatano. I really appreciate it! I will ask them and let you know.
1 - 4 of 4 Posts
