1 - 10 of 10 Posts
I am looking to purchase my first Graphics card. I have a 4-5yr old PC with a i7 processor, 8GB RAM, 460w PSU, and a 1080p 60hz monitor. I am not a huge gamer, but go in spurts where if I find one I like I will play for hours and then not play again for months. I have not made a budget yet, but will say that it will probably be at most $350. I will probably need a new PSU for the bigger cards, so realistically $300 and under. I do not plan to upgrade every year, so I want a card that will last at least 4yrs and still look better than current console games. AMD vs Nvidia does not matter to me. I know what I want, but I want to make sure I am not going overboard with what I actually need.
Originally Posted by WizardontheJob View Post
PCPartPicker part list / Price breakdown by merchant
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card ($304.99 @ Amazon)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Total: $360.98
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-02-08 12:28 EST-0500
You're likely to get a lot of different responses to this. Here's my flavor!
Honestly if you're going to get a 960 for 1080p and for $304, I'd rather get the 2Gb version for almost half that price: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487153
Refurbished but you get the 1 year warranty, should be just fine for 1080p 60hz and you save quite a bit for minimal performance loss (If you're able to use the 4 GB at all many times)
I disagree.
4 Gb of RAM is becoming very relevant these days. For example: I had a GTX 660 Ti FTW+ running GTA V. GTA V has an indicator in the settings menu that shows how much memory your current settings will use. I was at the memory limit way before I started loosing FPS.
I also would never consider refurbished parts for my machines, but that's me.
pass the lortabs
Vega + Water = Power
I'd recommend going with either a GTX 970 or the r9 390, depending on the game, they trade spots for which is faster. But going with the step down on either side is only around $50-60 less (Newegg pricing) and the performance difference is huge.
The benchmarks on this review are centered around the price point you're looking at, so this should give you a good idea of how the cards stack up: http://anandtech.com/show/9784/the-amd-radeon-r9-380x-review
Super Moderator
R9 390 is the best bet for around $300. I got my R9 290 for $200 used, and the performance is very similar to the 390.
PC Evangelist
390 since its 8GB. Nice to have the extra vRAM for the next 4 years. You might not need it but its better to have.
1 - 10 of 10 Posts
