nero that allows me to burn avi/wma format??
643 Views 15 Replies 13 Participants Last post by  Coma
I dont know if im confussed but everytime i try and burn a movie in avi and wma format i cant.. i have Nero 9 ultra and it only looks for bup,vob,ifo files.. What do i need to do so i looks for avi/wma file formats?
1 - 16 of 16 Posts
Anyone got any suggestions?
Or even a different burning program i can get that allows me to burn any format (avi,wma)
Can't you just burn as a Data disk?
isoburn. Or even Windows DVD Maker is good.
Click Nero Startsmart, go to Photo & Video, and choose "Make Your Own DVD-Video." Then just click "Add Video files...", and go from there.
Use nero vision which should be in nero 9 ultra
I like this program convertXtoDVD, it converts virtually any video file and burns it automatically to a dvd for you
nero is too complicated at time and its video conversion is behind the times IMO (very slow)
Please use the edit button
like someone else said, burn them in DATA format will retain, well, it's format
Hey Blasphemy,
I don't know if you ever got an answer to your question about your video format conversion using NERO, but I use NERO for some of that stuff, however the program I use for most of my Video conversion and I recommend whole heartedly is "AVS Video Converter". I have been using it for years with outstanding results. Google it, research it and take a look at it at http://www.avs4you.com/ ; It's great, easy to use and has a whole lotta stuff that comes with it. For most of my audio conversion, I use Nero, but when Nero dosen't work for me, I use the free "Mediacoder" at http://mediacoder.sourceforge.net/ and just navagate to "Downloads". Let me know if this works here or at [email protected].
Hope this helps, take care
Bobby
In order to play AVI/WMV on a DVD player, you need to convert it to what DVD players play (vob etc)
use ConvertXtoDVD and it will encode pretty much any format to DVD files and it burns it for you. A DVD player doesn't have the decoders for playing AVI/WMV directly off a Data Disk/DVD
Download and install Nero Codec Pack 1.0, and you should be able to playback or burn many extra formats not usually supported by Nero. AVI should be supported already by Nero though.
It contains these plugins:-
Audio Plugins:
· AAC/MP4 AudioCoding.com Advanced Audio Coding
· AAC/MP4 PsyTEL Advanced Audio Coding
· APE Monkey's Audio Lossless Compression
· ASF/WMA Microsoft Windows Media Audio 9 Lossy/Lossless
· FLA (FLAC) Free Lossless Audio Codec
· PAC (LPAC) Lossless Predictive Audio Compression
· MP3 Lame MPEG-1 Layer-3
· MPC MusePack
· OFR OptimFROG Lossless Audio Coder
· RM/RA RealNetworks RealMedia/RealAudio
· SHN SoftSound Shorten Lossless Compression
· SPX (Speex) Open Source Audio Compression For Speech
· WV WavPack Hybrid Lossless Compression
· MP3Pro encoder/decoder
Video Plugins:
· MPEG-2 SVCD
· MPEG-2 DVD
Originally Posted by Jax2foru
Hey Blasphemy,
Bobby
This really looks like spam, though I'm inclined to believe it's not.
Please, try to structure your posts less like a classifieds ad, and avoid bringing threads back from the dead
Also, it is unwise to post your email on public websites.
1 - 16 of 16 Posts
