1 - 4 of 4 Posts
Questionnaire galore!
I'm trying to install Intel RST v13.1.0.1058 and it's complaining it can't find .Net Framework 4.5 even though by default Windows 10 already has 4.7 which should be backwards compatible.
I already tried putting on 3.5 from Windows and Features.
And I already tried Compatibility mode.
None of them work.
I know this version of RST should work with Windows 10 since I had it installed before I formatted, but I can't remember if I needed to do some voodoo magic to get it installed or it was just a straight install on the older builds of Windows 10.
Overclocker in training
Hi,
You could try to install an older benchmark and see if it will install you older net...
From memory catzilla would install 3.5
http://www.catzilla.com/download
One like 3DMark might use 4.5
https://www.techpowerup.com/download/futuremark-3dmark-timespy/
But possibly you should be doing all this from device manager instead
Installers might not work with win-10 and you have to use update drivers point it to the extracted folder of the drivers you already downloaded.
I don't think your reply is related?
I'm trying to install Intel Rapid Storage Technology Driver and software here... not a Benchmark.
Hi,
Like i said lastly
Download IRST to downloads folder...
Right click it and select Extract all to the downloads folder too
Go the device Manager,
Expand Storage devices
Right click the first listing under Storage devices
Select Update driver
Choose the second option to search your computer....
Point it toi the extracted folder.
Select Okay.
The IRST driver should now be updated.
1 - 4 of 4 Posts
